It is currently Sun Aug 03, 2025 12:58 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
PostPosted: Sat Jul 13, 2019 5:51 pm
I need to remove kerfing so I can redo the job correctly. Any advise on doing this or do I just take a chisel and start working ?
PostPosted: Sat Jul 13, 2019 5:59 pm
What kind of glue did you use and when was the original kerfing installed?
PostPosted: Sat Jul 13, 2019 6:24 pm
A few weeks ago . Fish glue
PostPosted: Sat Jul 13, 2019 8:47 pm
Online
How does fish glue undo?
I need to do that from time to time, I use a clothes iron from the outside and try to get the pallet knife in there, mindful not to attempt to much twisting of the knife to remove it. In other words, don't try to use the knife as a lever, you can blow your sides if not careful..
These users thanked the author meddlingfool for the post: James Orr (Sat Jul 13, 2019 11:20 pm)
PostPosted: Sun Jul 14, 2019 3:43 am
I thought some moisture with the heart would be efficacious.
PostPosted: Sun Jul 14, 2019 10:29 am
"I thought some moisture with the heart would be efficacious."
Really it's nothing to cry your heart out over! pizza
PostPosted: Sun Jul 14, 2019 11:39 am
gaah I think I meant heat laughing6-hehe
PostPosted: Sun Jul 14, 2019 12:07 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I like the phrase “water with the heart” better. Agua con corazon.
PostPosted: Sun Jul 14, 2019 4:37 pm
I got most of it off w a sharp brace carving chisel ... sandpaper will handle the rest.
Ed, moisture w fish glue
PostPosted: Fri Jul 19, 2019 1:41 pm
When I finish the rekerf.... do I simply plane it down flush to the sides or do I need to go back to the radius dishes?
B
PostPosted: Fri Jul 19, 2019 2:51 pm
B
I’d chalk the kerf or make witness lines with a pencil, then re-sand. It shouldn’t take too long. You’ll want the new material to be properly radiused. :)
PostPosted: Fri Jul 19, 2019 5:43 pm
Online
Back to the dishpit with ya!
PostPosted: Sun Jul 21, 2019 1:47 pm
Last Name: Beaver
City: Lake Forest
Yes, Ed is so right, back to the dishpit ya be.
Joe Beaver
Maker of Sawdust
PostPosted: Sun Jul 21, 2019 4:24 pm
City: Escondido
Zip/Postal Code: 92029
So I read and re-read the last two post. I couldn’t understand why you guys were being so harsh and vulgar. It turns out I may have been transposing the sh/p. :)
PostPosted: Mon Jul 22, 2019 5:30 am
laughing6-hehe Don't think harsh and vulgar at all! Think radius dish slave pit gaah again!
PostPosted: Mon Jul 22, 2019 5:19 pm
Arrrrrgg! To the dishpit!!!
PostPosted: Tue Jul 23, 2019 10:12 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
So relining the body with kerfed lining...OK. it needs to go in slightly proud (1/32" is perfect) and re-radiused using the same approach taken the first time.
- Beth Brower
PostPosted: Wed Jul 24, 2019 7:50 am
I DID get it re-dished :) it was, though a challenge as the back is glued on already... I was going to take a chance on the thinned lining, but decided to rekerf it instead of wondering if the top would fly off...
So what I had to do was lay the rim w the mold down upside down on the dish and do my best to keep even pressure as I rotated it around... the mold was heavy enough to add weight so It didn’t take forever and I did get the radius reapplied as well as taken out of the upper bout:)
Ready for the ol top:)
PostPosted: Wed Jul 24, 2019 9:53 am
That's better!
PostPosted: Wed Jul 24, 2019 9:57 am
Online
That's how I do all mine. Move the frame, not the dish. But I had my dish custom made to about 2"...
Not sure how I feel about that gap under the neck block...
These users thanked the author meddlingfool for the post: SnowManSnow (Wed Jul 24, 2019 10:01 am)
PostPosted: Wed Jul 24, 2019 10:04 am
Well the gap only proceeds up to the kerfing. There is a strip around the top that is the same width as the rest of the kerfing. It’s the same kind of thing you can see on the tail block at the bottom where the top will go. I don’t see a lot of tension there, definitely not more than on the top at the tail block, so I figured why not free that are up to move.
Now, all that said, I’m just playing compared to
the things you do and if there’s a reason NOT to do that I’d happily listen to it and make appropriate adjustments next time.
Thanks Ed
PostPosted: Wed Jul 24, 2019 10:12 am
First name: Big
Last Name: Jim
es bein mi amigo [:Y:]
PostPosted: Wed Jul 24, 2019 11:01 am
Online
Part of the reason guitars need neck resets is the forward rotation of the neck block, accompanied by the back flattening in that area. I’m not sure how much having the bottom of the block glued prevents this, but that’s why Spanish heels and c block style construction exists.
I’ve never done any deliberate experiments, but it’s my understanding that a gap like that is generally considered not a good idea by consensus.
If you look at chladni patterns of backs, there’s not a lot going on there anyway.
I’m sure with some digging you can find previous threads on it...
These users thanked the author meddlingfool for the post: SnowManSnow (Wed Jul 24, 2019 12:03 pm)
PostPosted: Wed Jul 24, 2019 11:03 am
Online
That being said, I do chamfer the tail block to lining width on the top...
PostPosted: Wed Jul 24, 2019 12:04 pm
Thanks Ed
Users browsing this forum: meddlingfool and 27 guests
